cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Korky
Jul 16, 2012Aspirant
ddoming73 wrote: Korky,
I have been running a dual core E6700 for more than a year on my pro pioneer. I have the same SYS temp as you do. I have tried several different fans and have been unable to lower it. My theory is that it is hotter because of the higher FSB speed of the E6700 processors vs. the stock E2160
So, I doubt you could go any lower than what you already got there.
However, I'm thrilled that someone has gotten the q6700 working on the Pro. Good job!
ddoming73
Does your CPU or SYS fans ever stop running when in idle or sleep mode?
Im sure when I had the stock CPU in the NAS the fans would power down when in sleep mode or when the disks were spin down mode but now both fans are always on, even when the disks have spanned down
