cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Korky
Jul 28, 2012Aspirant
Thanks ddoming73,
That's the same conclusion i have came to - like you have gone back to the E6700.
Instead of the improved cooling setup (very unlikely i think because of the limitation of the NAS) might be worth looking in a different direction....
what about a different quad processor with lower TDP that will work with the NAS?
I don't think there is one out there right now but things might change. If i find anything I will post back
