cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
ddoming73
Aug 01, 2012Tutor
Hi Korky,
I have managed to procure an HFC-10828-C2 heatsink. Can you tell me what did you do to adapt it to the Readynas?
Did you simply remove the screws from the stock heatsink and put them in the new one, or did you have to purchase specific screws?
