cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
brettgavin
Aug 20, 2012Tutor
Hi,
I'm not sure if anybody else is interested, but I'm having a new left-side panel made for my Pro6. The new panel will add 20mm to the depth of the panel. The point of this is to allow room to fit a replacement heat sink other than the HFC-10828-C2. Unlike ddoming73, I haven't been able to locate any online so far.
The new depth inside the box should be >73mm.
I'll post pictures when I receive the new panel.
If it works out, is anyone else interested in one?
