cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
CompuTutor
Sep 21, 2012Aspirant
Westyfield2 wrote:
"So on the ‘new’ Pro 6 (RNDP6000-200) the motherboard VGA header is in fact a 15pin connector,
not a 12pin connector like the old one had."
I am the new owner of a RNDP6xxx-100NAS,
and I DO have the 15 (16 -1-Plugged) pinout.
Were -100's shipped with the 12-pin pinout too ?
I am currently doing testing,
but in a few weeks I'm game to test anything.
I can and will do the 1333 test if my chipset/firmware supports it.
On the fan/heatsink issue.
A simple trick is to use the stock OEM panel,
but cut it out for the taller heatsink/fan,
then use a 4" or 6" "Dome" style speaker grill.
Simple, and low cost...
Whats the EXACT difference from the -100 to -200 anyway ?
Is it a SATA-150 or SATA-300 buss device as an example ?
I ask, because the hardware compatibility list is ONLY for -200 units !
Three different calls yielded confirmation of this,
and no legacy list is still posted on the website.
Perhaps someone has the link for the old (-100) HCL ?
I am unsure what drives will work,
and things I've read elsewhere confirm
the -200 list (current) is folly for a -100. :(
At least for some of the 2-TB and one of the 3-TB...
We could sure use it on the "Wayback Machine" to help out.
In any event, it will be torn down and stripped bare,
that N/S heatsink is coming off without a doupt,
and hopefully chipset numbers will be there for us.
It will be going back on with active cooling of course.
I will be compiling a set of tight HQ pics of all,
and hope to show here, if permitted anyway.
It's a dead duck in their eyes now, should be fair.
What mini-PC card is that anyway ?
It is obviously NOT a custom build,
it has serial ports, audio ports,
and of course a VGA port as noted.
and many jumpers that are undefined.
Sure hope we figure that one out.
