cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
mdgm-ntgr
Sep 21, 2012NETGEAR Employee Retired
Later first-gen Pro units might have stronger similarities with the Pro 6 than earlier first-gen Pro units.
The Pro 6 has a faster CPU than the Pro and some other newer hardware necessary to support that. So if you want to upgrade the CPU (voids warranty) you'll be able to upgrade to a faster CPU in the Pro 6 than you could in the Pro.
Support should've been better informed than that. The compatibility list is still there for the first-gen Pro: http://kb.netgear.com/app/answers/detail/a_id/20641
The Pro Business Edition is e.g. the RNDP6000-100 whereas the Pro Pioneer Edition is the RNDP600E-100. When the system is running you should see in Frontview and in RAIDar which you have as well.
