cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
marcusp
Sep 29, 2012Tutor
Westyfield2 wrote:
The bit that mentioned “Broadwater” intrigued me, as that’s not AMI’s address! Broadwater was the Intel codename for the P965/G965/Q965 chipsets. Now that could of-course be wrong, but lspci reckons it's an Q963/Q965 chipset too. In the previous post http://www.readynas.com/forum/viewtopic.php?f=35&t=29284&start=90#p367951 we listed the Chipsets and what CPUs Intel say are compatible, so adding these possibilities to the list gives:
- For the Q963 Intel list only the E6700 - so if this is the chipset surely the Q6700 and E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the P965 Intel list the E6700 and Q6700 - so if this is the chipset surely the E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the G965 Intel list the E6700 and Q6700 - so if this is the chipset surely the E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the Q965 Intel list only the E6700 - so if this is the chipset surely the Q6700 and E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the DP965 Intel list the E6700 and Q6700 - so if this is the chipset surely the E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the G31 Intel list the E5300, the E6700, the Q6700, and the E7400.
If you watch the video in this review, maybe it'll help you :) ! The guy removed everything in the nas, even each part of the mobo.
http://www.decryptedtech.com/storage-and-networking/netgears-readynas-pro-6-looks-like-a-pc-inside-a-nas-body/Page-3
