cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
chirpa
Dec 07, 2012Luminary
When you guys post the CPUs you try, can you also mention what the revision sticker says on the board? It is a small white/green/etc sticker under the CPU heatsink on the board. Earlier boards (under rev6) will have issues with the newer CPUs for sure).
