cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
MastaMind
Feb 08, 2013Initiate
Forgot to give you my fan and temp readings and version.
Radiator 4.2.22
Fan SYS 942 RPM OK
Fan CPU 2083 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 28.5 C / 83 F [Normal 0-85 C / 32-185 F] OK
Radiator 4.2.22
Fan SYS 942 RPM OK
Fan CPU 2083 RPM OK
