cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dsm1212
Feb 20, 2013Apprentice
Add me to the list of e7600 upgrades. Took less than 10 minutes to make the swap. System came right up. This is a -200 rev pro6 with Flame 2.0 bios. Picked the cpu up used for $51 delivered. I think it was pulled from a 27" imac. I'll keep the old one in case this was abused but so far it looks good. Temp is 3 degrees cooler than the stock one, but I blew a lot of dust out of the fan and case while I had it open. Running 24x7 I guess its probably a good idea to clean out the dust more frequently!
-steve
# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 23
model name : Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz
stepping : 10
cpu MHz : 3058.990
cache size : 3072 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 xsave lahf_lm dts tpr_shadow vnmi flexpriority
bogomips : 6117.98
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 3058.990
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 6117.66
clflush size : 64
power management:
-steve
# cat /proc/cpuinfo
processor : 0
cpu family : 6
model : 23
stepping : 10
cpu MHz : 3058.990
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 6117.98
clflush size : 64
power management:
processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 3058.990
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 6117.66
clflush size : 64
power management:
