cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
chirpa
Feb 26, 2013Luminary
There may be even newer BIOS now, but I don't work there anymore to know that.
You can try running this add-on (install in FrontView, don't need USB boot anymore), which will update to the latest I had at the time: http://www.readynas.com/download/addons ... .5-x86.bin
That v0.5 add-on provides these BIOS versions:
- Ultra2/ReadyNAS-ProUltra2 (1102/v1.8)
- Ultra4/ReadyNAS-NVX-V2 (0823/v1.1)
- Ultra6/FLAME6-2 (0610/v1.1)
- Pro(6)/FLAME6-MB (0726/v2.0)
