cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
puntocom
Mar 01, 2013Tutor
It works! Went from stock E2160 with 1GB DDR2 to a E7500 and 4GB DDR2. Speeds before:
snorlax:~# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 2034 MB in 2.00 seconds = 1017.25 MB/sec
Timing buffered disk reads: 572 MB in 3.00 seconds = 190.54 MB/sec
and speeds after the upgrade
/dev/c/c:
Timing cached reads: 3990 MB in 2.00 seconds = 1996.06 MB/sec
Timing buffered disk reads: 946 MB in 3.00 seconds = 315.31 MB/sec
Looks good to me! Thanks for your help! I think my mainboard was Flame6 v1.1
/dev/c/c:
/dev/c/c:
