cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
fastfwd
Mar 02, 2013Virtuoso
All those numbers seem low to me. Are you sure you ran the tests while the NAS was otherwise idle? Also, did you run the tests a few times? There can be significant run-to-run variation in the results.
Here's the best result from ten runs on my system:
ReadyNAS Pro Pioneer
CPU: 2.4GHz E6600 SL9ZL
RAM: 8GB
Drives: 2 x ST2000DM001, 2 x ST3000DM001
RAM: 8GB
nas1:/etc/default# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 8894 MB in 2.00 seconds = 4454.85 MB/sec
Timing buffered disk reads: 1234 MB in 3.00 seconds = 411.04 MB/sec
