cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dsm1212
Mar 02, 2013Apprentice
I can't get near that. You definitely have 7200 RPM drives I see. Maybe that's the difference. I have all the performance features enabled in Frontview since I have a UPS, do you? Or maybe our memory is still running at 800Mhz, but I can't find a way to tell.
steve
steve
