cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
fastfwd
Mar 02, 2013Virtuoso
dsm1212 wrote: You definitely have 7200 RPM drives I see. Maybe that's the difference.
It might explain the difference in the results of the buffered-read test, but the cached-read test isn't affected by drive speed. Your processor is faster than mine, right? And your memory should be running at least as fast as mine, so I don't know why my throughput is apparently twice as high as yours.
I have all the performance features enabled in Frontview since I have a UPS, do you?
Yes.
Or maybe our memory is still running at 800Mhz, but I can't find a way to tell.
dmidecode shows "unknown" for my memory speed, so I can't find a way either...
