cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
soremaniac
Mar 03, 2013Aspirant
Mmh i tried it with a Q6600 (4Core) in After the BIOS Update the ReadyNAS 6 worked perfekt. So i went an took my ReadyNAS PRO with the Q6600 i get this (Even After the BIOS Update).
Sat Mar 2 18:58:21 CET 2013 System is up.
Sat Mar 2 18:14:26 CET 2013 System is up.
Sat Mar 2 18:01:01 CET 2013 VBAT power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:01 CET 2013 3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:01 CET 2013 VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC3 power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 AVCC power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 DDB18 power is out of normal range [expected: 1.80 current: -0.00].
Sat Mar 2 18:00:40 CET 2013 Gerät fährt herunter
Sat Mar 2 18:00:40 CET 2013 Bitte schließen Sie diese Browsersitzung und melden Sie sich nach dem Neustart mit RAIDar wieder an. Das System fährt jetzt herunter...
Sat Mar 2 18:00:33 CET 2013 Fan 1 has failed (SYS -1 rpm).
Sat Mar 2 18:00:33 CET 2013 VBAT power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC3 power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 AVCC power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 DDB18 power is out of normal range [expected: 1.80 current: -0.00].
