cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
chirpa
Mar 03, 2013Luminary
Weird. I though those were read off the board, they are power voltages. Maybe the chipset doesn't work well with that CPU, causing some issues.
If the system appears to work otherwise when you see those errors, I can provide a boot script work around, to have the system not log those errors.
