cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
fastfwd
Mar 06, 2013Virtuoso
dsm1212 wrote: Well, it seems like hdparm is not very accurate.
Yeah. The throughput tests should be run only when the system is idle, and they should be run a few times; the fastest result is the most accurate one. I usually do a series of ten runs over a couple minutes, and I often see a 2:1 range of speeds.
dsm1212 wrote: By the way fastfwd, what os rev are you running? I'm running 4.2.21.
4.2.22, with the 07/26/2010 BIOS (which Netgear calls 2.0 and AMI calls 8.14).
