cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
bzhpedro
Mar 08, 2013Aspirant
Hi guys,
Actually I have the original ReadyNAS Pro Pioneer Edition (bought in 2009) with this bios revision :
07/26/2010 FLAME6-MB V2.0 (Thanks to chirpa's bios_update addon).
It's actually running a Core 2 Duo E6700 @2.66GHz and 2x2Gigs DDR2 PC6400 Crucial and I would like to know if i can upgrade the CPU, because I find that the E6700 is powerful but hot.
Thank you
Thank you
