cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
soremaniac
Mar 11, 2013Aspirant
it always depends on your Board Version, and the Firmware. I have a first Gen. ReadyNAS Business and the best what i can use in it is a Intel E6600 (2x 2.6 GHz / 4 Cache / Bus 1066MHz). In a second ReadyNAS PRO Business, but much newer, a Intel Q6600 (4x 2.6 GHz / 8 Cache / Bus 1066MHz) is runing just perfekt AND COOLER! Always check the TEMP on your CPU under full load.
But you cut put practically any CPU that fits this Profile: 1.) the Socket LGA775 2.) Busspeed max. 1066MHz
and i think in some Mainbordversions only Max TDP 65W but this is variable you have to find out.
(as far i found out, more Cache on the CPU is better than more GHz)
Like these
E6600 or E6700 (runs hotter)
http://ark.intel.com/products/27251/Int ... 66-MHz-FSB
some say the E7600 is the fastes
http://ark.intel.com/products/41495/Int ... 66-MHz-FSB
or Q6600 (i think the Best)
http://ark.intel.com/products/29765/Int ... 66-MHz-FSB
or Q6700 (runs hotter)
http://ark.intel.com/products/30790/Int ... 66-MHz-FSB
Oder ev. X6800 (runs hotter)
http://ark.intel.com/products/27258/Int ... 66-MHz-FSB
or ev. QX6700 (runs hotter)
http://ark.intel.com/products/28028/Int ... 66-MHz-FSB
and don't forget:
Like these
and don't forget:
chirpa wrote:
There may be even newer BIOS now, but I don't work there anymore to know that.
You can try running this add-on (install in FrontView, don't need USB boot anymore), which will update to the latest I had at the time: http://www.readynas.com/download/addons ... .5-x86.bin (Link Fixed)
That v0.5 add-on provides these BIOS versions:
Ultra2/ReadyNAS-ProUltra2 (1102/v1.
Ultra4/ReadyNAS-NVX-V2 (0823/v1.1)
Ultra6/FLAME6-2 (0610/v1.1)
Pro(6)/FLAME6-MB (0726/v2.0)
