cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Freek1
Mar 11, 2013Aspirant
Thanks for your quick and detailed reply!
I'm not sure what version the ReadyNas Business Pro I am planning to buy is, but I do know that it is 4 years old.
So if I understand it correctly, the first Gen does not support quad-core CPUs but your second gen supports quadcore CPUs, right?
I am mainly interested in the E7600 because it's TDP is the same as the original CPU and should suffice for my needs.
The link in the last quote to he BIOS is broken
Thanks!
soremaniac wrote: it always depends on your Board Version, and the Firmware. I have a first Gen. ReadyNAS Business and the best what i can use in it is a Intel E6600 (2x 2.6 GHz / 4 Cache / Bus 1066MHz). In a second ReadyNAS PRO Business, but much newer, a Intel Q6600 (4x 2.6 GHz / 8 Cache / Bus 1066MHz) is runing just perfekt AND COOLER! Always check the TEMP on your CPU under full load.
Thanks!
