cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
bzhpedro
Mar 11, 2013Aspirant
It's possible. I really like the Pro with the E6700 but I do not find a better cooler which can fit in the ReadyNAS to cool this great CPU the way it should be cooled.
Chirpa, do you have any idea if a third party cooler could fit ?
Thank you
Thank you
