cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
soremaniac
Mar 11, 2013Aspirant
bzhpedro wrote: Thank uou Chripa, I already found a link for a cooler (http://www.coolmod.com/product/3765/0/0 ... -Cobre.htm) but i do not find it anywhere in stock. That's why I am asking, and i do not want to do anything on the panel.
I would like to find a 3rd party fit to fit replacement ;-)
I am pretty sure it does not exist, but I will never know if I do not ask
I don't know, but i think this will not work, becouse the fan on the ReadyNAS is fixed to the Board with scrus, the fan on the pic has some kind of clip like the orginal intel fan's and i cut not mout this fan with these "clip-system" to the readynas board.
http://www.coolmod.com/images/product/1/large/pl_1_4_3765.jpg
i may be wrong but, then tell me how...
