cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
fbmachines
Mar 16, 2013Guide
Is there a certain revision Q6600 that if likes better (SL9UM or SLACR)?
From what I read, the newer SLACR runs cooler so if it's compatible I'd like to run that one.
Also, for those running a Q6600 what cooler works the best without modding the case?
Thanks!
Thanks!
