cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
fbmachines
Apr 10, 2013Guide
I took the plunge and and popped an E7600 (SLGTD) in my main Pro6. I'm using the stock cooler and the idle & stressed temperatures seem to be identical to the original CPU. I used IC Diamond thermal paste. This was a beta Pro6 unit that was updated to the linked firmware. I'll pull the cover again to check board revision.
Plex transcoding is smooth as butter with everything I've thrown at it.
Best $45 upgrade IMHO.
