cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
soremaniac
Apr 22, 2013Aspirant
karex wrote: Hi Mike,
My Pro with the Q6600 makes warnings too. Do you have some solution? Thanks, Karel
is it like these here?
https://www.readynas.com/forum/viewtopic.php?f=35&t=29284&start=150#p387419
Than you have to do this (like chirpa says):
https://www.readynas.com/forum/viewtopic.php?f=35&t=29284&start=150#p387444
chirpa wrote: On boot up, RAIDiator firmware looks at the system type, and builds a layout for monitor_enclosure (health check program, adjusts fans, sends alerts). Easiest way to deal with your logs is to modify that layout (saved in ramdisk) and restart moitor_enclosure. I haven't tested this out, but it should hopefully work, maybe needing a few tweaks: # cat /etc/rc2.d/S02readynas_enclosureThis removes the voltage lines from the layout, then restarts the service. So it won't know to read the voltages, causing logs/email alerts. If you look at /ramfs/enclosure.cfg, you can also see references for the temp/fan sensors.
#!/bin/bash
sed '/^vol/d' /ramfs/enclosure.cfg > /tmp/enc.$$$
mv /tmp/enc.$$$ /ramfs/enclosure.cfg
killall monitor_enclosure
sleep 1
/frontview/bin/monitor_enclosure
I had to do a similar boot script for my retro-fitted Repertoire. I replaced the Sparc board with x86 (Ultra4 board). Since the Repertoire chassis has no fans, the system would complain that the fan has failed. The script I used there would tell the system there was no fans to monitor (over the default Ultra4 layout), so no more alerts would occur.
Hope that helped
Mike
