cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
DavidtHulin
Apr 30, 2013Aspirant
I feel like I owe this thread my results:
I have a "new" Pro and upgraded to Q6600 SLACR. Used from eBay. At the same time I upgraded the CPU-cooling to a Dynatron P199 - this cooler fits vertically, the only issue I can imagine is that some condensators on the mobo would in some cases hinder a snug fit - but not in my case. The P199 should be able to handle 130W, so I tried first with a QX6700 - it didn't even start. It handles the 95W of the SLACR @ <50%. It hovers between 48-51C.
Two points:
Firstly, apparently this fan is loud. I don't care. The RNS is in a closet next to a noisy switch.
Secondly, I am now able to transcode 3 1080 videos and stream them at the same time. This is the only performance I measure.
David
Two points:
David
