cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
noadvertise
May 20, 2013Tutor
chirpa wrote: Yes, you can upgrade it to 8GB RAM.
sweet, thanks for the info chirpa! do i need to stick with the slower 800mhz ddr2 or can i go with 1066 DDR2 - i read something about a problem with cooling when faster ram is installed.
