cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Squazz
May 22, 2013Aspirant
dsm1212 wrote: I'm not sure what the upgrade options are for an Atom processor, but it won't be the E6700 or Q6600. It would be an updated Atom processor if any. Might want to start a separate topic since you are right that all the discussion here for processor upgrades was about the Pro 6. If you have SSH access there are utilities you can install to print out some info about the system, but there is also a nice NASMON addon you might want to look at which shows a fair amount of info. I think that requires the PHP addon.
steve
I might create a new topic then, thanks for your input :)
Edit: Thread for Pro 4 can be found here: http://www.readynas.com/forum/viewtopic.php?f=35&t=71148
