cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
noadvertise
Jun 16, 2013Tutor
ddoming73 wrote: Hi everybody,
I couldn't resist and went and bought the Q6700 for my readynas Pro Pioneer. However, installing it wasn't as straightforward as I thought. Once installed, the system started sending out scary alarms like:
DDB18 power is out of normal range [expected: 1.80 current: -0.00].
AVCC power is out of normal range [expected: 3.30 current: -0.00].
VCC3 power is out of normal range [expected: 3.30 current: -0.00].
VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
VBAT power is out of normal range [expected: 3.30 current: -0.00].
However, the CPU seemed to be running fine. After some research I traced the cause to the /frontview/conf/enclosure.db file. Fortunately this file is a sqlite DB, which I could modify. To make a long story short, you have to change the paths where the system looks for voltage and temp data from /sys/class/hwmon/hwmon2 (which assumes a dual core CPU) to /sys/class/hwmon/hwmon4 (which assumes a quad core CPU).
I wonder if the people that tried quad core CPUs before ran into this too? Maybe this format was introduced recently? I'm running Radiator 4.2.21
I know it's too much to ask but maybe netgear can make this conf more CPU independent in later releases?
can we make the short story a bit longer? :D Does that mean replace all instances of hwmon2 with hwmon4 - or only specific instances?
I just put in my quad and am getting those errors... also getting a fan failure error
Fan 1 has failed ( -22 rpm).
