cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Xaver
Jul 06, 2013Tutor
Hi,
finally I have also upgradet the CPU of my Pro 6 from E2160 to E7600 (Board FLAME6 v1.1.)
first try won't work but after upgrading the BIOS from something/2008 to this 07/26/2010 FLAME6-MB V2.0
(http://www.readynas.com/download/addons ... .5-x86.bin from here viewtopic.php?f=35&t=29284&start=135#p387035)
it worked :)
my idle temp is 3C° more, about 56C° which is fine for me (Room temperature is 28C°, no air-con in the office :( )
I have 4GB (4-5-5-18 DDR2) Memory, maybe I will upgrade this at well to 8GB :)
so now VirtualBox should be fine for running win8
it worked :)
