cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
ATCIS
Jul 08, 2013Tutor
chirpa wrote: There may be even newer BIOS now, but I don't work there anymore to know that.
You can try running this add-on (install in FrontView, don't need USB boot anymore), which will update to the latest I had at the time: http://www.readynas.com/download/addons ... .5-x86.bin
That v0.5 add-on provides these BIOS versions:
- Ultra2/ReadyNAS-ProUltra2 (1102/v1.8)
- Ultra4/ReadyNAS-NVX-V2 (0823/v1.1)
- Ultra6/FLAME6-2 (0610/v1.1)
- Pro(6)/FLAME6-MB (0726/v2.0)
Has anyone tried using this BIOS Update method on a Pro running OS6 v6.0.8. If so did you have any success?
EDIT/P.S.: I just tried this on an Ultra 4 running OS6 v6.0.8. I got an error that said "Error: Only Debian package is allowed". So I'm guessing that this will not work on the Pro either. . .
If not, is there an alternative method for performing the BIOS update without having to go back to Frontview v4.2.23?
Additionally, is this the latest and greatest BIOS revision that we currently know of?
Thanks in advance!
