cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
mdgm-ntgr
Jul 08, 2013NETGEAR Employee Retired
You have to install dmidecode and flashrom via apt-get. Then download the add-on onto the NAS and extract the contents of the add-on .bin manually, look at the contents of install.sh and run flashrom manually. Do make sure to check the current bios version and make sure to attempt to flash the correct BIOS.
I haven't tried this recently but it did work for me some months ago so I presume it would still work.
