cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
bishoptf
Jul 16, 2013Aspirant
Looking at upgrading my ultra 2 and getting a pro 6 from the bay to upgrade, is there a certain model, I know pro 6 but of the pro 6 models is there better ones to try to go after (or avoid). Is there a way to tell with the pictures if a version is a newer vs older version like the location of the display etc....
Thanks in advance :)
