cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
bishoptf
Jul 16, 2013Aspirant
mdgm wrote: The ReadyNAS Pro 6 is the RNDP6000-200. It has "ReadyNAS" written at the bottom right on the front of the unit.
Thanks for the usual quick reply, just reading through the threads it appears there are dofferent versions and I wasn't sure if the later ones were better then the older ones, so I thought I would ask. For example I see some with an LCD and some without, does it matter when wanting one to upgrade the CPU etc.
