cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
mdgm-ntgr
Jul 16, 2013NETGEAR Employee Retired
All 6-bay units have a display on the front.
If you want to upgrade the CPU in a system running 4.2.x the best unit to get is a Pro 6. But you replace the CPU at your own risk.
