cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Campus
Nov 02, 2013Luminary
Seems to be quite low. My E7600 shows around 20.5C but that one runs at 3GHz. Are you sure you really had 50C for the E2160 cpu? Mine had an idle average of 25C.
