cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Hibtek
Nov 02, 2013Aspirant
I'm pretty sure......although I am getting old now
this is my Ultra 6 + which is in the same room, this is a stock unit, running an E5300,................and I have just looked at that, because that was running at 52-57 and now is running at 30-31!
ok, I think I need more coffee.......and maybe an increase in the old medication!
Device Description Status
Disk 1 Seagate ST2000DM001-9YN164 1863 GB , 40 C / 104 F , Write-cache ON OK
Disk 2 Seagate ST2000DM001-9YN164 1863 GB , 41 C / 105 F , Write-cache ON OK
Disk 3 Seagate ST2000DM001-1CH164 1863 GB , 37 C / 98 F , Write-cache ON OK
Disk 4 Seagate ST2000DM001-1CH164 1863 GB , 34 C / 93 F , Write-cache ON OK
Fan SYS 937 RPM OK
Fan CPU 2057 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 31 C / 87 F [Normal 0-85 C / 32-185 F] OK
UPS 1 Not present NA
The Ultra 4 + is running about normal though
Disk 1 WDC WD20EARS-00MVWB0 1863 GB , 34 C / 93 F , Write-cache ON OK
Disk 2 WDC WD20EARS-00MVWB0 1863 GB , 35 C / 95 F , Write-cache ON OK
Disk 3 WDC WD20EARX-00PASB0 1863 GB , 33 C / 91 F , Write-cache ON OK
Fan SYS 1800 RPM OK
Temp CPU 52 C / 125 F [Normal 0-80 C / 32-176 F] OK
Temp SYS 37 C / 98 F [Normal 0-65 C / 32-149 F] OK
Any idea how to create load on the cpu?
Fan SYS 937 RPM OK
Fan CPU 2057 RPM OK
Fan SYS 1800 RPM OK
