cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Hibtek
Nov 02, 2013Aspirant
:-) I ran the cat /dev/urandom > /dev/null and it only did one processor, never though its as simple as just opening two sessions :-)
Ran it on both, and temp climbed up to 34c, left it for 5 mins and it reached 36c, stopped them and it dropped by 10c by the time I refreshed frontview :-)
Fan did not appear to change from 928 rpm though, but I guess its not getting hot enough to speed it up?
Thanks
Thanks
