cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Campus
Nov 02, 2013Luminary
Let it run for at least 30 minutes to get enough heat into the case to really stress test everything. Both fans should run at max speed then.
