cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Campus
Nov 02, 2013Luminary
Here are my numbers:
Idle:
Fan SYS 942 RPM OK
Fan CPU 1622 RPM OK
Temp SYS 56 C [Normal 0-65 C / 32-149 F] OK
Temp CPU 24 C [Normal 0-60 C / 32-140 F] OK
With stress load:
Fan SYS 998 RPM OK
Fan CPU 2960 RPM OK
Temp SYS 59 C [Normal 0-65 C / 32-149 F] OK
Temp CPU 48 C [Normal 0-60 C / 32-140 F] OK
Idle:
Fan SYS 942 RPM OK
Fan CPU 1622 RPM OK
With stress load:
Fan SYS 998 RPM OK
Fan CPU 2960 RPM OK
