cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
fastfwd
Dec 05, 2013Virtuoso
dhl wrote: I have one main goal - maximum speed without increasing temperatures while keeping all stock cooling (fans and heatsinks).
E6600 will give you that, especially if you get the right S-Spec number (SL9ZL, not SL9S8).
