cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dhl
Dec 05, 2013Luminary
fastfwd wrote: E6600 will give you that, especially if you get the right S-Spec number (SL9ZL, not SL9S8).
Great, I'm seeing a bunch of them on eBay, many >$20 :D
So is this essentially a plug and play operation - i.e. no firmware hacks or cooling mods needed, just swap and go?
