cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dsm1212
Dec 06, 2013Apprentice
Have some fresh thermal paste on hand and while you are in there blow out the fan thoroughly. I actually saw my temps drop a bit but I think it was because of the cleaning :-). I'm using an e7600 I bought on ebay. That processor was frequently removed from a mac and updated so there are quite a few used around.
steve
steve
