cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dhl
Dec 06, 2013Luminary
@dsm1212
Yes, will do on the thermal paste. Really great that you're seeing *cooler* temps! Do you know the S-Spec number number for your e7600? Really great that you're seeing *cooler* temps!
