cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
spiderman1
Jan 08, 2014Guide
I have now upgraded my Readynas Pro with a Q6600 and it screams. I can transcode blu-ray at 5120 kbits/s using the Air Video without any jittering or interruptions whatsoever.
Here are how my temp and fan readings while idle:
Fan SYS 856 RPM OK
Fan CPU 1854 RPM OK
Temp SYS 54 C / 129 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 27 C / 80 F [Normal 0-85 C / 32-185 F] OK
Here are how my temp and fan readings while transcoding one stream at 5120:
Fan SYS 922 RPM OK
Fan CPU 3182 RPM OK
Temp CPU 45 C / 113 F [Normal 0-85 C / 32-185 F] OK
hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 8410 MB in 2.00 seconds = 4211.72 MB/sec
Timing buffered disk reads: 1208 MB in 3.00 seconds = 402.16 MB/sec
HTOP
1 [||||||||||||||||############################96.7%] Tasks: 64, 56 thr; 6 running
2 [||||||||||||||||||||||||||##################91.4%] Load average: 3.36 1.19 0.89
3 [||||||||||||||##############################94.0%] Uptime: 03:24:04
4 [||||||||||||||||||||||||####################96.7%]
Mem[|||||||||||||||#**********************1164/3956MB]
Swp[ 0/2047MB]
I hope this helps any of you who are toying with the idea of upgrading your Readynas Pro to a Q6600. For $70 from ebay, it's sweet indeed!
Fan SYS 856 RPM OK
Fan CPU 1854 RPM OK
Fan SYS 922 RPM OK
Fan CPU 3182 RPM OK
/dev/c/c:
HTOP
Swp[ 0/2047MB]
