cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dhl
Jan 12, 2014Luminary
Well that was easy! :D
Dropped in a E6700 SL9ZF purchased on eBay for $23. Took about 2 minutes (I spent more time cleaning the enclosure).
BEFORE CPU:
AFTER CPU:
BEFORE - timed reads (best of 10)
AFTER - timed reads (best of 10)
BEFORE - temperatures and fans
AFTER - temperatures and fans
Maybe it's my imagination but Frontview seems much snappier. So does connecting and viewing files in the Finder.
Great upgrade - totally worth it and recommended! Thanks everyone, for your help! :woot:
BEFORE CPU:
ReadyNAS_Pro:/# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
stepping : 13
cpu MHz : 1795.269
cache size : 1024 KB
AFTER CPU:
processor : 0
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
stepping : 6
cpu MHz : 2660.311
cache size : 4096 KB
ReadyNAS_Pro:/# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 2520 MB in 2.00 seconds = 1260.87 MB/sec
Timing buffered disk reads: 396 MB in 3.00 seconds = 131.91 MB/sec
/dev/c/c:
Timing cached reads: 9502 MB in 2.00 seconds = 4759.45 MB/sec
Timing buffered disk reads: 436 MB in 3.03 seconds = 143.73 MB/sec
Fan SYS 897 RPM OK
Fan CPU 1971 RPM OK
Temp SYS 56 C / 132 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 38.5 C / 101 F [Normal 0-85 C / 32-185 F] OK
Fan SYS 932 RPM OK
Fan CPU 2083 RPM OK
Temp CPU 27 C / 80 F [Normal 0-85 C / 32-185 F] OK
