cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dsm1212
Jan 13, 2014Apprentice
Good results. I've never gotten to the bottom of why my e7600 system does so poorly at the hdparm test. I'm getting:
# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 3692 MB in 2.00 seconds = 1846.18 MB/sec
Timing buffered disk reads: ^[[A776 MB in 3.01 seconds = 258.22 MB/sec
warehouse6:/c/home/admin# hdparm -t -T /dev/c/c
I'm definitely using inexpensive 4TB drives (unsupported) but it seems like these results are off by 2-3x. Not that I'm complaining. I've got the box doing a lot of stuff and having no issues. Just seems like something is wrong. No uncorrectable reads on any drives or errors in /var/log. System looks mostly idle when I ran the above command several times. It makes me wonder if have a performance setting I should change. I think I have them all enabled in frontview (I've got a ups). Any suggestions?
steve
/dev/c/c:
steve
