cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
dsm1212
Jan 16, 2014Apprentice
There are some differences in our disk configuration so it's the first numbers for "Timing cached reads" that I'm more interested in. I downloaded some software called ramspeed and it shows my system getting about the same 4GB/s that fastfwd gets from hdparm. Near as I can tell that seems to be the right number for 800MHz DDR2. So whatever is going on in my system it seems to be specific to running hdparm.
