cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all, Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports. I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowe...
Sandshark
Mar 02, 2014Sensei
I haven't been keeping up on the OS 6 thread to see if anyone has upgraded to OS6 after replacing the cpu and if the unsupported OS6 is as hackable as the older OSes. I wouldn't mind being on a newer kernel where I could use KVM.
Some certainly have and I think I'm about to. I only went to the E6600 since I already had one I had pulled from a Windoze machine that I went quad on, but I'm about to get another and may go to E6700. I don't do transcoding, so the E6600 was more than enough boost for me.
My take on OS6 is that it's more hackable because it's based on a more up-to-date kernel, so there is more that's compatible. I'm not a Linux guru and have stuck mostly with the pre-compiled install packages for RAIDiator, so I'm going in deeper with OS6.
